ChuckieCheese
Jan 28, 2017Luminary
Orbi: We really need separate SSID for 2.4 Ghz and 5Ghz or speed is limited to less than 200 Mbps
TLDR: With Orbi, my 5Ghz capable devices are "forced" to connect to 2.4 Ghz most of the time, slowing down speed. Tested against 3 different routers and my 5Ghz capable can connect to 5Ghz network al...
mostlyfoild
Jun 25, 2017Tutor
I’m confused by the first paragraph of this post TheEther on every device (client) I connect to my wifi usually I am given the choice of either the 2.4 or the 5Ghz network to connect to. They have different SSIDs... and unique passwords which I have created. Therefore I am able to connect high throughput devices like iPhones and AppleTVs to the 5Ghz do they get super fast browsing/streaming speeds and things that require little or no speed (like LIFX or Hue) to the 2.4 account. It’s also worth noting that I can’t get SONOS to see Orbi at all.
st_shaw
Jun 25, 2017Master
mostlyfoild If you want Sonos to connect to Orbi, you might try going into the GUI, Advanced, Advanced Setup, Wireless Settings and uncheck "Enable 20/40 MHz Coexistence" This has allowed some of my 2.4G-only devices to connect to Orbi.
I have Sonos, but personally I would never connected it using WiFi. Sonos has its own sophisticated mesh network, and that works extremely well. It's a true mesh network and can cover an entire home exceptionally well.
