ChuckieCheese
Jan 28, 2017Luminary
Orbi: We really need separate SSID for 2.4 Ghz and 5Ghz or speed is limited to less than 200 Mbps
TLDR: With Orbi, my 5Ghz capable devices are "forced" to connect to 2.4 Ghz most of the time, slowing down speed. Tested against 3 different routers and my 5Ghz capable can connect to 5Ghz network al...
st_shaw
Jun 25, 2017Master
TheEther Respectfully, you need to reread that Apple link more carefully. It does not state a different roaming threshold for 5Gz. What it says is that 5Ghz APs are usually overlapped at the -67 dBm level, and therefore macOS clients will hang onto an AP longer than expected. (Due to the -75 dBm roaming threshold, you can travel far into another APs zone before the client will switch.)
If you are reading something else that I missed, please correct me, but here is the passage:
"macOS clients monitor and maintain the current BSSID’s connection until the RSSI crosses the -75 dBm threshold. After RSSI crosses that threshold, macOS scans for roam candidate BSSIDs for the current ESSID.
Consider this threshold in view of the signal overlap between your wireless cells. macOS maintains a connection until the -75 dBm threshold, but 5 GHz cells are designed with a -67 dBm overlap. Those clients will remain connected to the current BSSID longer than you expect."
TheEther
Jun 25, 2017Guru
Indeed, I am mistaken. Thanks for the correction!
