ChuckieCheese
Jan 28, 2017Luminary
Orbi: We really need separate SSID for 2.4 Ghz and 5Ghz or speed is limited to less than 200 Mbps
TLDR: With Orbi, my 5Ghz capable devices are "forced" to connect to 2.4 Ghz most of the time, slowing down speed. Tested against 3 different routers and my 5Ghz capable can connect to 5Ghz network al...
mostlyfoild
Jun 25, 2017Tutor
st_shaw re SONOS as its own mesh, I can only connect the speakers to a wifi network or via Ethernet to a switch, is there another way I’m missing? I’ll try and edit the GUI options though re coexistence.
- st_shawJun 26, 2017Master
mostlyfoild wrote:
st_shaw re SONOS as its own mesh, I can only connect the speakers to a wifi network or via Ethernet to a switch, is there another way I’m missing? I’ll try and edit the GUI options though re coexistence.mostlyfoild To use Sonos mesh you connect one, and only one, speaker, bridge, or boost to a wired port. Since Orbi uses a 40 MHz width in 2.4 GHz you also need to use Channel 1 on Orbi and channel 11 on Sonos, or vice versa. Lastly, the Sonos units need to be close enough to establish a path from the wired unit to each unit. Sonos will figure out the path, and will hop through intermediate units if required.
- rhester72Jun 26, 2017Virtuoso
I do find it interesting that, almost without exception, it's Apple device owners clamoring for split SSIDs for each channel.
Has anyone actually taken this up with Apple, given it appears it's their firmware/chipset that is having difficulty with 5GHz affinity and roaming?
Rodney
- peteytestingJun 26, 2017Hero
Rodney
lol apple wont comply with anything the rest of the world wants as they are unto themselves , hell look at 2.4 gig you still need to set it to 20mhz for apple devices to work
apple though where on the same track , eg remove the control from the users hands and make it work better themselves , look at the way roaming works with apple devices , its far better and the main reason is there is no user intervention in that process and they use better but non standard means to achieve it
so i dont be thinking apple would otw your idea anytime soon
pete
