ChuckieCheese
Jan 28, 2017Luminary
Orbi: We really need separate SSID for 2.4 Ghz and 5Ghz or speed is limited to less than 200 Mbps
TLDR: With Orbi, my 5Ghz capable devices are "forced" to connect to 2.4 Ghz most of the time, slowing down speed. Tested against 3 different routers and my 5Ghz capable can connect to 5Ghz network al...
mostlyfoild
Jun 25, 2017Tutor
TheEther that’s correct, I believe the point of the thread is us saying to Netgear that we would like to access seperate SSIDs on seperate frequencies. There is no way for me to explicitly force my iPhone to connect to the 5G part of a single SSID
peteytesting
Jun 25, 2017Hero
but the logic of the way the orbi works with its ap and band steering means that it would degrade its performance if you had separate ssid's and roaming would far less a positive experience
if you want separate ssid's im not sure orbi is your answer as i cant see netgear changing the the thing that makes orbi what it is and thats automated whole home wifi
