ChuckieCheese
Jan 28, 2017Luminary
Orbi: We really need separate SSID for 2.4 Ghz and 5Ghz or speed is limited to less than 200 Mbps
TLDR: With Orbi, my 5Ghz capable devices are "forced" to connect to 2.4 Ghz most of the time, slowing down speed. Tested against 3 different routers and my 5Ghz capable can connect to 5Ghz network al...
mostlyfoild
Jun 25, 2017Tutor
I’m not sure that I agree. I think it’s a software change which would be easy to implement. I only want to be able to choose a bandwidth in certain instances, I.e. for my iPhone which needs the speed offered by 5G, all the 200 other devices can roam onto whichever bandwidth Orbi puts them on
- peteytestingJun 26, 2017Hero
mostlyfoild wrote:
I’m not sure that I agree. I think it’s a software change which would be easy to implement. I only want to be able to choose a bandwidth in certain instances, I.e. for my iPhone which needs the speed offered by 5G, all the 200 other devices can roam onto whichever bandwidth Orbi puts them onthe software change would esentially remove the very purpose and design of the orbi compared to any other router and repeater setup
the issue you cant do it for just some devices as its all or none its that simple
