ChuckieCheese
Jan 28, 2017Luminary
Orbi: We really need separate SSID for 2.4 Ghz and 5Ghz or speed is limited to less than 200 Mbps
TLDR: With Orbi, my 5Ghz capable devices are "forced" to connect to 2.4 Ghz most of the time, slowing down speed. Tested against 3 different routers and my 5Ghz capable can connect to 5Ghz network al...
mostlyfoild
Jun 25, 2017Tutor
st_shaw re SONOS as its own mesh, I can only connect the speakers to a wifi network or via Ethernet to a switch, is there another way I’m missing? I’ll try and edit the GUI options though re coexistence.
st_shaw
Jun 26, 2017Master
mostlyfoild To use Sonos mesh you connect one, and only one, speaker, bridge, or boost to a wired port. Since Orbi uses a 40 MHz width in 2.4 GHz you also need to use Channel 1 on Orbi and channel 11 on Sonos, or vice versa. Lastly, the Sonos units need to be close enough to establish a path from the wired unit to each unit. Sonos will figure out the path, and will hop through intermediate units if required.
- rhester72Jun 26, 2017Virtuoso
I do find it interesting that, almost without exception, it's Apple device owners clamoring for split SSIDs for each channel.
Has anyone actually taken this up with Apple, given it appears it's their firmware/chipset that is having difficulty with 5GHz affinity and roaming?
Rodney
- peteytestingJun 26, 2017Hero
Rodney
lol apple wont comply with anything the rest of the world wants as they are unto themselves , hell look at 2.4 gig you still need to set it to 20mhz for apple devices to work
apple though where on the same track , eg remove the control from the users hands and make it work better themselves , look at the way roaming works with apple devices , its far better and the main reason is there is no user intervention in that process and they use better but non standard means to achieve it
so i dont be thinking apple would otw your idea anytime soon
pete
- aazOct 10, 2017Virtuoso
rhester72 wrote:I do find it interesting that, almost without exception, it's Apple device owners clamoring for split SSIDs for each channel.
Has anyone actually taken this up with Apple, given it appears it's their firmware/chipset that is having difficulty with 5GHz affinity and roaming?..
Not sure which apple devices are having difficulties, I have iPhones ranging from 5S to 7, two apple TV's, 3 iPads ranging from 4 to Pro and a Macbook Pro connecting, I don't have any issues using the network. They are using the 5Ghz network when possible and dropping back to 2.4 when it becomes iffy. I'd say people complaining are creating their own problems by not using devices as they are supposed to be used and doing custom settings where none are warrented.
- khadOct 10, 2017Apprentice
All I can say is that creating a separate 5GHz network and only connecting to that has been rock solid for me (and my Apple devices). I guess it's possible that there is a problem on Apple's end, but the solution that's been working with 100% reliability for me was entirely in the Orbi itself.
We can point fingers all day long, but that won't fix anything for anyone. I'm a pragmatist in that regard I suppose.
I was about to send my Orbi back until I created the separate 5GHz network. It was dropping out at least once a day if not more. I haven't had a single dropout for months now. YMMV
