ChuckieCheese
Jan 28, 2017Luminary
Orbi: We really need separate SSID for 2.4 Ghz and 5Ghz or speed is limited to less than 200 Mbps
TLDR: With Orbi, my 5Ghz capable devices are "forced" to connect to 2.4 Ghz most of the time, slowing down speed. Tested against 3 different routers and my 5Ghz capable can connect to 5Ghz network al...
st_shaw
Nov 26, 2017Master
You need a high-end very capable WiFi device to get top speed. I get an average of 470 Mbps with an iPhone 7+ when connected to the Orbi router, and 380 Mbps when connected to the satellite. That's about as good as it's going to get.
Moh_V
Nov 26, 2017Aspirant
The same edge+ device that can reach 300+ mbps with verizon router directly, can only reach 92 mpbs approx going thru orbi. That to me sounds like an issue with orbi, unless there is some other configuration further hidden in orbi. Isn't it?
