ereimers
Sep 17, 2018Aspirant
Orbi wi-fi So slow
I subscribe to Gig speed internet from Xfinity. When I'm plugged into the modem/router from Xfinity I'm able to download typically around 800-900 mbps. When I hooked my ORBI I download at speeds of 2...
ereimers
Sep 19, 2018Aspirant
FW: 2.1.4.16
Xfinity - gigabit 900 mbps
Model:TG3482G
Vendor:ARRIS Group, Inc.
My house is roughly 2,000 sqft the main Orbi and the satellite and the main Orbi unit are about 100 feet from each other. When I've been testing I am in the same room as the main unit.
I did all of your suggestions below but I'm still coming up with the same results.
I'm pulling my hair out, unfortunately, it's been way past the time I can return the product.
Sep 20, 2018Guru - Experienced User
What mode is the ISP modem running in? Model only or router?
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
What speeds do you get when wired with a PC to the Orbi router? Testing wireless, you don't see anything near 900Mb. May around 400-500Mb depending upon wireless device design and support.
100feet mabye a too far in between. I would close the distance and test, say 40-50feet? I set mine up at 40 feet between the router and just 1 satellite. Great speed and coverage.
After configuring the modem to one of the option above, I would do a factory reset on the Orbi router, then setup from scratch and this time, make sure you don't enable QoS, Traffic Meter or access controls. Run a wired speed test.
- Blanca_OSep 24, 2018NETGEAR Employee Retired
Hi ereimers,
We’d greatly appreciate hearing your feedback letting us know if the information FURRYe38 provided has helped resolve your issue or if you need further assistance.
Blanca
Community Team
