mickgibs
Apr 24, 2019Initiate
Orbi wifi dropouts
Hi folks,
I promise I've searched the forum before posting this, as I know it's similar to other posts, but I couldn't find anything that would help.
I've had the orbi RBK50 system for about a week and we've lost wifi connection a couple of times. The first time a recycling of both the base unit and satellite fixed it and the second time just a recycling of the satellite seemed to do the job.
In my case all the wireless devices are actually still connected to Orbi but the internet doesn't work.
It updated the firmware after I got it so I'm sure I'm on the latest.
Anyone know what's going on, or what the proper fix is?
This is a premium product, why would this be happening and plaguing so many customers?
Regards
Mick
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
What WPA security modes are you using?Try enabling Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).- mickgibsInitiate
Are you serious?
It's going to take my whole afternoon to troubleshoot that?
Jesus Christ.
Perhaps I'm better off raising a support case with Netgear directly?
Regards
Mick
FURRYe38 has went through the basic troubleshooting for the Orbi. If you've searched the forums, you'd have read this several times. Its 101 for making sure the orbi is setup and not having interference issues.
Its surprising how many issues can affect wireless network performance and whats needed to optimize it. It was much simpler when wireless first came out and there wasn't as many devices broadcasting on it. In the current generation, you need to do some basic troubleshooting before assuming a device is bad.
