danall22's avatar
danall22
Orbi Wifi Issues yet again
I have yet again got issues with my Orbi - i seem to have them on a constant basis and i have no idea why? I am running 1 x RBR50 in router mode and 2 x satelites.
I have to regularly re-start them to get them to work and more often than not its the satelites that cause the issue - anything that is connected to them does not have an internet connection. I can log in and see that it apparently does but they will not work. So unplugging and plugging back in solves the issue.
I have tried loads and loads of things - daisy chain off, on, IPV6 on and off and all the suggested regular settings on and off and just when i think it is working works for a few weeks then i have issues again. When this happens and say i am connected to the office RBS i can not even log into the router to check the settings even though it is showing a connection to the wifi so there is clearly some issues here and i am at a loss on what to try next. I have tried so many times to get it to work. I am not a network specilist and want a plug and play system and this has been anything but.
I am close to just sending the items back to amazon under a claim of faulty
  • FURRYe38's avatar
    IF you have that ability then you may want to send the system back to Amazon if you have tried various troubleshooting steps.
    • danall22's avatar
      danall22
      I updated the software to the latest version on Friday so it’s the newest one. The modem is a draytek vigor130. The home is 1200sq foot but needed the satellites for IP cameras that are outside so have to get through brick walls. There is less than 30ft between the units but not much less than this as they are on corners of the house.
      • FURRYe38's avatar
        Brick will be problematic for any wifi system.
        Has a factory reset been performed since last update? I presume v16 is what you got loaded?
