batpot's avatar
batpot
Tutor
Apr 22, 2020
Orbi wifi not visible
My primary WiFi is working - multiple devices are connected to it, but it's not visible, and there's no settings to make it visible.
What gives?
  • FURRYe38's avatar
    What Firmware version is currently loaded? V16 is available for download.
    Is the Orbi system operating in Router or AP mode?
  • CrimpOn's avatar
    CrimpOn
    It would be helpful to know how you administer the Orbi system.  The Orbi "app" has no settings to change whether the WiFi network SSID is being broadcast.  The Orbi web interface, on the other hand, has a provision to have the Orbi "Broadcast" or "not broadcast" the SSID on both the 2.4G and the 5G WiFi channels.
    This is on the Advanced Tab, Advanced Settings, Wireless Settings.
  • Retired_Member's avatar
    Retired_Member
    What gives?
    Visible?   Visible to what or who?
    • batpot's avatar
      batpot
      Tutor
      SSID broadcast
      The guest wifi has a radio box to enable SSID broadcast, butprimary WiFi does not.
      (Often this setting is called "make visible", and I was going to memory)
      • FURRYe38's avatar
        Is the 2.4 and 5G SSID Broadcast check boxes checked and enabled under Advanced Tab/Advanced Settings/Wireless Settings?
        They should be by default. If they are and you don't see your SSID name on any device, factory reset the RBR and setup from scratch with a wired PC. Before you start the setup wizard, look on your devices for the Orbi## SSID name, it should be seen here. If its seen, start the setup wizard and complete it. I recommend giving a new custom SSID name and PW. The name should be intuitive and or fun.
        batpot wrote:
        SSID broadcast
