Orbi666
Oct 13, 2019Initiate
ORBI Wifi Problems
We have had the ORBI wireless system for nearly two years now. One Master and One sattelite. We have had CONSTANT problems with the wifi. We have had intermittent drops for devices, bandwidth iss...
Glauman
Mar 13, 2020Initiate
I’ve had the same bad experience. Frustrating that Orbi wants me to pay them to get their product to work.
- FURRYe38Mar 13, 2020Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).Above suggestions working:
https://community.netgear.com/t5/Orbi/Throttling-Devices-RBK53/m-p/1858561/highlight/true#M81925
Glauman wrote:
I’ve had the same bad experience. Frustrating that Orbi wants me to pay them to get their product to work.- Retired_MemberMar 13, 2020
FURRYe38 wrote:What Firmware version is currently loaded?
Glauman wrote:
I’ve had the same bad experience. Frustrating that Orbi wants me to pay them to get their product to work.:smileymad:
- Spud2599Jun 01, 2020Tutor
Glauman wrote:
I’ve had the same bad experience. Frustrating that Orbi wants me to pay them to get their product to work.This is nonsense that people who buy ORBI for it's ease of setup/use need to get these deep into setup to get their product to work. I'm not putting down FURRYe38 as he gives great info...
