Orbi666
Oct 13, 2019Initiate
ORBI Wifi Problems
We have had the ORBI wireless system for nearly two years now. One Master and One sattelite. We have had CONSTANT problems with the wifi. We have had intermittent drops for devices, bandwidth iss...
Mar 13, 2020Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
Above suggestions working:
https://community.netgear.com/t5/Orbi/Throttling-Devices-RBK53/m-p/1858561/highlight/true#M81925
Glauman wrote:
I’ve had the same bad experience. Frustrating that Orbi wants me to pay them to get their product to work.
Retired_Member
Mar 13, 2020
FURRYe38 wrote:What Firmware version is currently loaded?
:smileymad:
