Lylemats
Sep 16, 2020Tutor
ORBI Wifi speeds slow
I have an ORBI RBR 50 and used to get 300 dl speeds over the air and the speed matched if i did it thru the app. Recently the speed thru the app is still the same 200-300 dl but if i check the speed over the wifi it drops to 12-20. Ive rebooted the system a number of times and the speed is still very slow. Sometimes in single digits. Help!
Be sure to do a backup configuration to file for safe keeping. This saves time if a reset is needed later on again. Please mark your thread as solved so others will know.
Enjoy. :smileywink:
- MstrbigMaster
Are all devices having the same slow speed or just 1?
Has anything changed since this has started?
If nothing has changed, it could be channel interference, or the device that is having the issue.
- LylematsTutor
Aloha
unFortunately all devices show that speed. I checked with my MacBook. iPhone and all of our iPads. So maybe 8 devices It used to work great. Not sure what changed. I haven't changed any settings.
thanks
lyle
- ChloeJInitiate
I have the exact same issue. It just started last week. I had no issues prior. Were you able to resolve it?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What is the size of your home? Sq Ft?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).One User Experience/Configuration:
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026Has a factory reset and setup from scratch been performed since last FW update?
Lylemats wrote:I have an ORBI RBR 50 and used to get 300 dl speeds over the air and the speed matched if i did it thru the app. Recently the speed thru the app is still the same 200-300 dl but if i check the speed over the wifi it drops to 12-20. Ive rebooted the system a number of times and the speed is still very slow. Sometimes in single digits. Help!
