MiTn's avatar
MiTn
Tutor
Jan 05, 2017
Orbi WiFi System & Arlo Cameras
I have a new Orbi Wifi System, but can't get my Pyle or Logitech web cams to work.  Will the Net Gear Arlo cameras work with the Orbi system?
  • I am running a Arlo camera system without issues. Dropcam cameras have issues staying connected with Beamforming and Mu-MIMO enabled
  • I'm running a rather large Arlo system and they work great with the Orbi.
    • TomMac's avatar
      TomMac
      Guru
      Same here... some Arlos ,some Pros , some Qs...all working fine with Orbi.
      Including second base off of the Satellite ethernet port.
      PS nice to see the Q on 5ghz, solved some2.4 interference
  • Are you running camera direct to Orbi internet or via a hub?
    • The Arlo and Arlo Pros have to run through the main Arlo base station. The Arlo Qs are connected to the Orbi via wifi.
      • loomis1975's avatar
        loomis1975
        Luminary
        I run Arlo Pros through their base station, which is attached to Orbi Satellite.  No problems at all.
