TeslaZ's avatar
TeslaZ
Follower
Nov 26, 2018
Orbi WiFi System (RBK50) AC3000
Folks,
Looking for some options with a new WiFi system.
I have a fairly complex home network with DSL (yes I know its all thats availabe in my area) and a router that is currently forward ports for servers, web servers and other applciations. I want to keep all the equipment I have and just get new WiFi, I have a 2 story home, and a shop pn the property that is all wired to the LAN.
I was wondering if the ORBI systems work in AP mode as a mesh system. I know of them don't but I can't really find the information. I see you can put them in AP mode, however I'm not sure how they work together after setting them in AP mode.
  • The RBK50 works fine in AP mode. IMHO, it works better as an AP than as a router. I found its routing abilities inferior to my Asus AC68U, so I continue to use that as a router with its wifi turned off. I have no issues with my 3 hard-wired Orbis. My mobile devices hand off smoothly as they move around the house.
    If you read through this forum, people's experiences vary a lot, sometimes inexplicably. You may get lucky or unlucky. If you decide to try Orbi, I recommend buying from whichever retailer offers the longest return period.
  • FURRYe38's avatar
    What is the distance between the router and satellite is 30 feet is recommended in between them to begin with depending upon building materials.
    TeslaZ wrote:
    Folks,
