Saved
Apr 03, 2018Aspirant
Orbi WiFi System RBK53 firmware 2.1.2.18 doesn't auto update to 2.1.3.4
manually download the files and manually update using IE11 or FF browser. Do a full factory reset on both router and satellite units after upgrading FW.
- SavedAspirant
Thanks for your reply. By the time I initiated the post, I had already done a manual update with Google Chrome, but without a factory reset.
I had basically created this post to let the community and Netgear tech support know that the firmware version 2.1.2.18 was not auto updating & therefore it could also be a problem that would be transfered to the new firmware version 2.1.3.4,
I figured Netgear probably did not consider fixing the Auto Update problem as they were creating the new firmware 2.1.3.4, due to possibly not being aware that such problem even existed.
Please do a full factory reset on the system and set up from scratch.
Savedwrote:Thanks for your reply. By the time I initiated the post, I had already done a manual update with Google Chrome, but without a factory reset.
