LRK_888
Mar 17, 2018Aspirant
Orbi WiFi System (RBK53) Power supply
Is the powers source to this system 110-240 compatible? Thanks
Mar 18, 2018Guru - Experienced User
Depending on what region you are. You will need to review the specs and user manual for that is supported on the power adapters. I presume there are different models.
LRK_888
Mar 18, 2018Aspirant
Hi,
Thank you very much for your answer, I tried looking at the specs but could not find it where it stated wether it was 110-240 or not. Is there a website I could find this informtion?
Regards
