msoi
Jun 04, 2017Aspirant
Orbi WiFi System (RBK53)
Hello! I plan on buying the Orbi Wifi System (RBK 53), I live an old apartment with several thick concrete walls and so finding the right placing for the router and the satellites may be an issu...
- Jun 05, 2017Yes both satellites have to be in range of the main router. Orbi is not a mesh system. It is a star system where the main router is at the center of the start and all the satellites fan out around the center do the strvand communicated to the center of the star and not to each other directly.
giantmike
Jun 04, 2017Initiate
How big is the house? I have a 4500 sq ft house with three floors and heavily insulated walls (yes, that includes all interior walls). The internet connection in this house is also in a corner on the front floor. I have found that the single router and satellite cover the entire house (and the garage, at long last) no problem.
to answer your question directly, pretty sure the satellites have to connect directly to the router.
- msoiJun 04, 2017Aspirant
Hi giantmike,
The house is around 6000 sq ft., so I think 2 satellites will cover the entire place. Or do you think one regular satellite and one wall plug satellite will be a better configuration?
Also, any idea if Netgear plans to add multi-hop topology to allow sattelites to connect with eachother?
Thanks!
