peltolivier
Dec 10, 2016Follower
Orbi WiFi System
hi, I want to install my orbi but i have a router and modem in 1 so do I need to buy a separate modem or not?
peteytesting
Dec 10, 2016Hero
hi
it depends on how you want to run it all and how your internet is connected
you can ether bridge the modem/ router you have so it works as a modem only and connect the orbi system behind it running as a router and connecting to the isp
or
leave the modem / router as it is and connect the orbi behind it and run the orbi system in ap mode
