MarcoM's avatar
MarcoM
Guide
Jan 07, 2017
Orbi WiFi System
I am having extreme long PING's with my ORBI RBR/RBS50 set, Pings are often over 110.000ms over satellite, whilst the backbone is running at 1733M (Satellite shows Blue @ boot
Also, I am having issues with the UTP ports on the RBR(BasRouter).
If I connect our SettopBox directly to the UTP port, we cannot watch TV. After 3-4 secs the sound stops, followed by a freezing image. If I connect it over a Netgear EX2700 Extender over the same Orbi router @ 400M, it works without a glitch.
The issues are present in Router and AP mode.
I have hard-reset both towers and installed the latest software version on Router and Satellite.
Does anybody have the same/sortlike experience and have any idea on solving it?
I feel like i'm having bought something terrible, instead of something awesome!
Marco
  • Exchanged my Orbi today.
    I have installed it minutes ago.
    It tuned out i really had a faulty set at first, and I am happy to report issues have been solved.
    Thanks for the help guys!
    Marco
  • Have you tried resetting the whole network? ie: turning off ALL devices, including Modem, Router, switches etc, then turning Modem/Router/Satellite/switches devices etc back on? I have noticed that with Orbi the network sometimes acts funny unless you reset everything in proper order when you first install it or after doing an Orbi reboot or firmware upgrade, perhaps you might also be experiencing some interferernce of some sort?
    • MarcoM's avatar
      MarcoM
      Guide
      Thanks for your answer!
      I have tried so much already, you wouldn't believe it. Everything has been shut down and had a cold reboot every single time.
      Funny thing is, the Base (Router) says there is no cable connected to WAN or 3 LAN ports (but there is) but traffic is registered over 'a' cable connection.
      I'm beginning to think I have some kind of hardware issue with the Base unit...
      I've dropped a screendump of my portlist on a website so you can see what I meen.
      There -is- a connection with WAN, but is says 'Link Down', also Ports LAN1,2,3 are free, but they show traffic?
      http://www.freeweb.nl/Orbi/OrbiPorts.jpg
      • Ely's avatar
        Ely
        Luminary
        I'm sorry you are having these issues, it can be really frustrating, have you made any changes to the Orbi's original internet configuration or any other changes besides defaults? I know it can be a pain specially if you have made changes, but have you tried a factory reset? have you tried different firmwares to see if the issue is not present with one of them? also maybe you got a lemon, are you in time to take it back to the store and do an exchange?
    Marco
    • Ely's avatar
      Ely
      Luminary
      MarcoM I'm very happy for you that you finally got it all setup, so glad you exchanged it on time too!
