Jasonnkh's avatar
Jasonnkh
Orbi WiFi System
Hi All,
I am interested in buying netgear orbi wifi system to install in my new house in singapore a hdb 4 room flat with a 93 square feet, there are different model and type. Need some advise like what model should i get? do I need to buy a twin pack or 3 pack in order to enjoy a full coverage at home? Thank you.
    • Jasonnkh's avatar
      Jasonnkh
      Hi Furry,
      As what you suggest is using just one single orbi router is enough, i don't need any additional satellites correct?
      Do i need to place the router at the center of the house or anywhere of the house corner to enjoy the full coverage?
  • FURRYe38's avatar
    Yes and placement on the main floor and center of the home is preferred.
