LoboTommy
Dec 25, 2018Luminary
Orbi wired and wireless backhaul
Actually RBK20 with 3x RBS20. So, today i wired up one satellite. Since then, the two wireless satelites has gone offline. I tried to sync, tried to set it up from scratch, but nothing I can not...
- Dec 25, 2018
LoboTommy wrote:
What the heck is daisy chain, and how do I disable it?Daisy Chain allows a Satellite to connect to another Satellite in a “Daisy Chain” topology instead of a “Star” topology where all Satellites can only connect to the Router (your RBR20).
You can find this setting when connected to Orbi’s GUI with a browser. Browse to orbilogin.com.
The setting is found under >> ADVANCED >> Advansed Setup >> Wireless Settings.
The choice to enable or disable Daisy Chain depends on your setup and how close your Satellites to your Router or other Satellites.
LoboTommy
ekhalil
Dec 25, 2018Master
- LoboTommyDec 25, 2018LuminaryFound it, turned it off, and voila! All satelites came back online. Hopefully stable this time.
- ekhalilDec 25, 2018Master
LoboTommy wrote:
Found it, turned it off, and voila! All satelites came back online. Hopefully stable this time.Glad that things are working now. Good luck!
- LoboTommyDec 26, 2018LuminaryActually. Network has been really unstable all through the night. So, today I disconnected the satellite that was wired, and set all three satelites back to wireless, then I let the kid get his ps4 connected with cable directly to the router instead.
It really seems that the mesh do not like that one of the satelites are wired and the rest wireless.
All three satelites wireless = stable network
