dg_sticks
Dec 22, 2016Guide
Orbi Wired Speeds Unacceptably Slow - Wifi Not Impacted - QoS Issues?
Ever since I have received my Orbi, I have been plauged with wired speed connection issues. My wired connection speed continues to be throttled from 10-20Mbps no matter what steps I take. My wireless...
dg_sticks
Dec 23, 2016Guide
Hi RonV42, thanks for the reply. I am indeed plugging right into the "switch" part of the base station (I have tried all three ports). I have turned off the satellite as well when conducting these tests, but still encounter the same issues.
I have done six factory resets before, but have not ever NOT visited the QoS page on the router's UI. Once I have time today, I will test this out and report back with my findings. To be honest, I'm not sure that this will do anything, but I am open to anything at this point. Thank you again.
RonV42
Dec 23, 2016Luminary
Here is another test you can try if you have a satelite unit set up. Each satelite also has a 4 port switch on it and has high wireless bandwith back to the main unit Plug the laptop into the satelite and see if you speed test shows improvement. This would determine if you have a bad switch in the main orbi unit.
