dg_sticks
Dec 22, 2016Guide
Orbi Wired Speeds Unacceptably Slow - Wifi Not Impacted - QoS Issues?
Ever since I have received my Orbi, I have been plauged with wired speed connection issues. My wired connection speed continues to be throttled from 10-20Mbps no matter what steps I take. My wireless...
darkneo29
Dec 26, 2016Star
Just downgraded firmware to .16 no factory reset..same issue
darkneo29
Dec 26, 2016Star
Back On Latest firmware. Then did factory wipe. Speed Test 500MB Down and 35MB up. Appears to be working. Only thing that I dont have like I did before is port forwarding manually setup for a few things and VPN enabled
- simonlinkeJan 21, 2017Aspirant
Can I clarify because I'm having very slow (2 Mbps) speeds wired but very good wireless speeds (350 Mbps) from the satellite unit. After you factory reset did you find you got good download speeds via ethernet from your satellite? i.e. The reset fixed the slow wired connection?
- darkneo29Jan 21, 2017Star
After a full reset my wired speeds are back to normal. Not sure why. Only thing I havent enabled again is VPN but everything has been working.,
Thank you.
