dg_sticks
Dec 22, 2016Guide
Orbi Wired Speeds Unacceptably Slow - Wifi Not Impacted - QoS Issues?
Ever since I have received my Orbi, I have been plauged with wired speed connection issues. My wired connection speed continues to be throttled from 10-20Mbps no matter what steps I take. My wireless...
ThePenguin
Feb 21, 2017Initiate
I have to say I am usually a Netgear fan, but they sorely disappointed me here. they were ZERO help, up to and including denying this thread even existed.
After going through some HORRIBLE attempted support from Netgear, this turned out to be a relatively simple fix for me. It had to do with the router connection speed and duplex in Windows.
Open your Network and sharing center
click on your connection (i.e. ethernet, local, etc), usually some color like blue on the right side of the window
Choose properties
Choose Configure
Click on the advanced tab
In the "Property" list choose Speed and Duplex
In the "Value" drop down choose Auto Negotiation
Click OK
In my case the router\Windows had set the speed to 100Mbs which is what was slowing down the connection speed. After having it auto negotiate, it set itself to 1.0 Gbps and viola! I have the correct connection speed on my wired desktop.
Hope this helps a few people here.
- loomis1975Feb 22, 2017Luminary
Thank you for the information. This will definitely go in the wired speed troubleshooting file. I did not have this issue, and frankly didn't know you could even set a ethernet port to throttle down like this.
I checked my ethernet adapter setting on 1 desktop and 4 laptops, and all of them were set for Auto Negotiation, which is I'm assuming the default. Also I rarely use the ethernet ports, except on the desktop.
I wonder how exactly it got changed, that is super strange. I'm glad you figured it out. Sounds like a hair pulling experience for sure.
- ThePenguinFeb 22, 2017Initiate
The predominate theory on how it got changed is that when the router initially talks to Windows, if it has trouble negotiating, it will default to the lowest acceptable setting. The interesting thing is that I removed the Orbi and put my Lynksys router back on before I figured this out and the Lynksys worked perfectly even though the setting had been changed (in other words the Lynksys software told Windows to change this apparently). Once I came across this as a possible solution, I reattached the Orbi and it defaulted back to 100Mbps. I then changed the setting to Auto Negoiate and it found 1.0 Gbps. Not sure why that would happen unless the firmware is some how set to accept the change in Windows settings.
My major frustration though, was in the fact that Netgear not only didn't help, but even went so far as deny the issue existed even when I provided a link to this thread. By the way, I was talking to their second level support at this time. Anyway, as with others, I only had the slow connection issue on the desktop I have hardwired. Wireless through put has been consistent at each attempt. My only issue was with the wired connection.
- HirrdgoonFeb 23, 2017Apprentice
Not sure why it was switching that setting in your setup, as I have never had a router switch the Auto Negotiate setting on me. I get full gigabit speeds when sending large files over my network using e.g. the last file i sent traveled at 115 MB/s steady from Wired Desktop -> switch 1 -> switch 2 -> switch 3 -> to Orbi Router -> switch 3 -> NAS.
Was this fixed with the new 1.5 firmware?
If only the orbi satellite worked with ethernet backhaul i could use it more efficently........
Desktop -> Orbi Satellite - > Switch 3 -> Orbi Router - > Switch 3 -> NAS
vs
- travisty357Mar 14, 2017Aspirant
ThePenguin Thanks for the tip. Worked great for me although I manually set to 1.0Gbps Full Duplex.
- darkneo29Mar 15, 2017Star
I swithed to AP mode and have had no issues since. There is a serious problem with these Orbi routers and ethernet cable. The support has been horrible. This will be my last netgear purchase. Again in AP mode I have no issues, so I am somewhat happy now after months of troubleshooting on and off.
- travisty357Mar 15, 2017Aspirant
"I swithed to AP mode and have had no issues since." Are you saying switching to AP mode increased your WIRED speed?
