dg_sticks
Dec 22, 2016Guide
Orbi Wired Speeds Unacceptably Slow - Wifi Not Impacted - QoS Issues?
Ever since I have received my Orbi, I have been plauged with wired speed connection issues. My wired connection speed continues to be throttled from 10-20Mbps no matter what steps I take. My wireless...
AMarket42
Apr 24, 2017Star
st_shaw: thank you for the explanation. I've found that it buffers when it's directly plugged into the Router, which seems odd to me. In any case, that allows some flexibility in placement.
I'll continue to see if it performs better wirelessly.
As for placement, any thoughts on how far apart? I'm sure it depends on other factors in the house but in general? I suppose if the lights are blue, that's all that truly matters but I didn't want them to interfere.
Anyway, thanks again!
Ares24
Apr 24, 2017Tutor
I have 250 up and down via fiber. Running speed tests on wifi on both phone, tablet, and laptop I will get anywhere from 50 - 125. Far cry from the 250 it "SHOULD" be getting. Not happy especially with all of the connection issues it has. For the money spent on this system, I should be able to plug it in and forget about it for awhile. Yes the occasional reboot is to be expected but spending hours troubleshooting is crazy.
- gfreyApr 24, 2017Apprentice
I have AT&T Gigapower Fiber internet and I get about 400Mbps via Ethernet on both of my Orbi Satellites. The Satellite placements are key to getting decent Ethernet performance. I have moved mine all around trying to find the optimal placement for both Satellites. I get anywhere from 100Mbps to 300Mbps via WiFi no matter where I am in my house or my backyard. If I had the Ethernet Backhaul option, I think I can get my speeds to +250Mbps. But I am pretty happy with my setup so far.
