EwanRGR
Feb 26, 2017Tutor
Orbi with 1 Satellite - Suggested Security settings?
Got the new Orbi with one satellite today, and install was a snap. Of course part of it was letting both update firmware before letting everything connect. Previously, I had my one router setup a...
- May 25, 2017
What I ended up doing was subscribing to a VPN service and making sure I run everything through that. I am still a bit concerned that the Orbi is too open and could be an issue, but it is pretty evident that there is no serious work being done to secure it. I guess that will be a factor when I do my next upgrade in early 2018.
EwanRGR
Feb 27, 2017Tutor
Anyone? I did hit iperf today, and was surprised to see that I am now IPv4 rather than IPv6, but I suspect that is from dropping to DHCP rather than using fixed IPs. Again, anything I should be looking for or configuring to minize my threat profile?
DarrenM
Mar 03, 2017Sr. NETGEAR Moderator
Hello EwanRGR
If you modem is a router/modem combo then you will need to bridge the modem or run the orbi as a AP.
DarrenM
