achadha99
Jun 17, 2018Follower
Orbi with ATT U-verse Wireless
I have read prior post of people having problems with the Orbi and ATT U-verse wireless. I wonder if there is a new fix to resolve the issue with using the Orbi system in AP mode as the primary broadc...
Jun 17, 2018Guru - Experienced User
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, LAN to LAN and configure AP mode on the Orbi router.
