entdgc
Mar 20, 2021Aspirant
ORBI with QNAP
My new Orbi RBR350 pack arrived today and have been installing it and updating to the latest firmware etc. Everything working now except I cant access my QNAP NAS. It shows up in the app with an Orbi...
CrimpOn
Mar 21, 2021Guru - Experienced User
entdgc wrote:
The IP address is 10.0.0.100 which is the same subnet as every other device (I have never seen these numbers on any other router...).
I cannot ping the NAS nor connect to it via the IP address.
Subnet 10.0.0.x is created when the Orbi is given an IP address in the 192.168.1.x subnet for its WAN port. Since the Plusnet is a combination modem/router, it has the public IP address on its own WAN port and has assigned IP's in the 192.168.1.x subnet to devices connected to it, including the Orbi router. Some ISP routers assign the 192.168.0.x subnet to devices, which leaves 192.168.1.x free for the Orbi LAN side.
entdgc wrote:
Today I have disconnected the modem lead (so no internet) rebooted Orbi so I have an independent network and the problem persists which implies it is something in the Orbi setup and not a conflict with my Plusnet router. The search continues....
Do you happen to remember when the NAS was set up if it was configured for DHCP or with a static IP address?
Does resetting the NAS erase storage? If not, I would try resetting the NAS. At least power it off and back on.
entdgc
Mar 21, 2021Aspirant
That makes sense. The PN router has indeed assigned 192.168.1.65 to the ORBI
It is DHCP configured though see from my other reply I am considering assigning an static ip if I can build up my confidence!
Thanks for your help so far.
- CrimpOnMar 21, 2021Guru - Experienced User
A static IP cannot hurt, but probably will not solve the issue.
Everything is connected to the Orbi, correct?
- entdgcMar 21, 2021AspirantYes. The only thing connected the the PN modem is the Orbi - everything else is connected to the Orbi either wired (NAS) or by WiFi.
- alokeprasadMar 21, 2021Mentor
Follow CrimpOn's advice. He knows more than most here.
The Orbi must be assigning 10.0.0.x IP addresses to other devices on your LAN. So why the other devices are reachable while the Qnap is not? I have no idea. How are you getting to (or will you get to) the Qnap's UI to look at or change settings if you can't reach it from your PC?
You could ask in the Qnap forum. People there are very helpful too.
