entdgc
Mar 20, 2021Aspirant
ORBI with QNAP
My new Orbi RBR350 pack arrived today and have been installing it and updating to the latest firmware etc. Everything working now except I cant access my QNAP NAS. It shows up in the app with an Orbi...
CrimpOn
Mar 21, 2021Guru - Experienced User
Which model of QNAP NAS is this?
I have been browsing the QNAP web site, and have not yet stumbled across any sort of User Guide.
(Just another check) prior to installing the Orbi, did the NAS respond to ICMP (ping)?
entdgc
Mar 21, 2021Aspirant
CrimpOn wrote:Which model of QNAP NAS is this?
It is a QNAP TS251. Yes I could ping before and still can if I replug everthing back into the Plusnet modem.
- CrimpOnMar 21, 2021Guru - Experienced User
Do you have that "QNAP Finder" program? Wonder what happens when it runs?
Thanks for the model number. Looks like the System Settings, Network icon shows how the ethernet ports are set up.
https://docs.qnap.com/nas-outdated/4.1/SMB/en/index.html?home.htm
Since there are two ports, it might be a hoot to connect the NAS to both routers.
- entdgcMar 21, 2021Aspirant
Since there are two ports, it might be a hoot to connect the NAS to both routers.Twas a hoot!
If I connect to both the Plusnet Router and the Orbi I get the following. First the overall configuration then the specific config for the Orbi connectionn and finally the Plusnet connection.
Just off to do a bit of testing in this setup...
Sorry about the pics - shouldnt be that hard!!! They were there in the preview!
So to recap I now have the NAS plugged directly into both the Orbi and the Plusnet Router.
If I connect laptop to the Plusnet I can access the NAS through the web interface using the PN ip address. Also I can see the music server running on the NAS. I can ping it.
If I connect laptop to the Orbi I CANNOT access the NAS through the web interface using the Orbi ip address. Also I cannot see the music server running on the NAS (but I can see the music player on the Orbi subnet). I cannot ping it. With the laptop still connected to the Orbi I can access the NAS through the web interface using the PN ip address. I can ping it using the PN IP even though the laptop is connected to the Orbi.
Go figure! I am totally confused.
entdgc wrote:Sorry about the pics - shouldnt be that hard!!! They were there in the preview!
One of the sad things about the Netgear community forum is that "in-line" images added using the camera icon do not appear until they are approved by a forum moderator (which can take hours). Images attached to the message using the "Browse" button in the lower left area available instantly. Truly a pain. I would have either (a) removed the camera icon, or (b) allowed pictures to appear. Heck, they allow only jpeg, ppg, pdf files. What is the problem?
Image attached is the first one mentioned above...
Seems you can only attach one image at a time !
Picture 2 mentioned above - details of the Orbi configuration
Picture 3 mentioned above - details of the Plusnet configuration
I remain totally unable to come up with even a theory about why the NAS does not appear to devices on the Orbi LAN.
However, I can explain the other situation. When a device on the Orbi LAN (10.0.0.x subnet) tried to open a connection to a device that is not on the subnet, it sends the request to the gateway (Orbi router) which does Network Address Translation (NAT) on it and transmits it.
The Orbi's WAN interface is on the 192.168.1.x subnet, so the connection has to be on some device on the same subnet. If the IP address being sought e is "anywhere else", the Orbi will send the connection request to its gateway (the Plusnet router), which will do the same thing. Orbi ARP's "who has 192.168.1.65?", the NAS responds, and the connection is opened. The NAS responds back to the Orbi router which "un-NATs" to figure out which device on its LAN side gets the response.
It works in this direction, but not in the reverse. If the NAS tried to connect to 10.0.0.27, it would say, "this cannot be on my local LAN (192.168.1.x), so I have to send the request to my gateway (Plusnet)." It has no idea where 10.0.0.x is except that it is NOT on the same LAN. I believe a REALLY sophisticated person might be able to figure out a way to use static route (or something) to let a computer know where to find 10.0.0.x, but that is WAY above my competence level.
CrimpOn wrote:I remain totally unable to come up with even a theory about why the NAS does not appear to devices on the Orbi LAN.
I hate it when people say "Put simply..." and then go on to speak technical gobbledeegook. This is NOT one of those cases - briliant explanation that I understood! TBH I have had it with this problem now. I will ring Orbi helpline tomorrow and if I cant get a solution I will take the Orbi back and go back to the TP-Link Archer 2800 it replaced.
Thanks CrimpOn
- CrimpOnMar 22, 2021Guru - Experienced User
I agree. One can only run headlong into a wall for so long before it ceases to be entertaining.
One you have learned the NAS IP address on the ISP router, can devices connected to the Orbi stream music, save files, etc.?
- entdgcMar 22, 2021Aspirant
Full disclosure - I have returned the Orbi today as I had a weekend of bangng my head against a brick wall with no success and no response from the Netgear help line. Typicaly I have tonight received a reply and in case it helps anyone else I will post it here. Obviously I cannot test this...
Enable Port Aggregation on your router:
1. Launch a web browser from a computer or wireless device that is connected to the network.
2. Enter http://www.orbilogin.net.
A login screen displays.
3. Enter the admin user name and password.
The user name is admin and the password is the one that you created during set up. The user name and password are case-sensitive.
The BASIC Home page displays.
4. Select ADVANCED>Advanced Setup>Ethernet Port Aggregation.
Enable LACP on QNAP NAS.
1. Use Ethernet cables to connect the QNAP NAS to Ethernet port 1 and port 2 on the router.
2. Launch a web browser to access the QNAP NAS management page.
3. Follow this link: http://docs.qnap.com/nas/4.0/en/index.html?network.htm
4. Go back to the router's UI and check if Port Aggregation status is now Active. - CrimpOnMar 22, 2021Guru - Experienced User
I cannot imagine how enabling port aggregation would change anything. The issue is not bandwidth, it is connecting in the first place.
