sgmidf
Nov 23, 2018Guide
Orbi with R7000 using Ethernet backhaul
Hello, I’m getting ready to set up a new system using and R7000 router with the Orbi system in access point mode. I planned to use ethernet backhaul. I currently have two separate lines running to ...
Nov 23, 2018Guru - Experienced User
Need to run two lines out from the Orbi base unit to the satellites. Or you can use a non managed switch in between the Orbi base and satellites if needed:
