sgmidf
Nov 23, 2018Guide
Orbi with R7000 using Ethernet backhaul
Hello, I’m getting ready to set up a new system using and R7000 router with the Orbi system in access point mode. I planned to use ethernet backhaul. I currently have two separate lines running to ...
ekhalil
Nov 24, 2018Master
sgmidf wrote:
......... Can I connect my Orbi base unit to a LAN port and the other lines to the other LAN ports of the R7000? Or do I need to run the 2 lines off of the Orbi LAN ports? In other words do I have to put the main Orbi ahead of the satellites or can they all be connected to the R7000 (acting as a switch)?
It should be ok to use the R7000 as a switch and connect the router and satellites through it.
- FURRYe38Nov 24, 2018Guru - Experienced User
He want to use the R7000 as his main host router, not as a switch. The satellites need to be connect directly to the satellite base or thru a LAN switch thats connected to the R7000 router. This will work.
- sgmidfNov 25, 2018GuideEkhalil is correct that I’m interested in using them Ian ports of my R7000 as a switch. I can add another switch if necessary, but it seems as if it should work without the additional switch. The most important thing is is I don’t need to run the lines to the satellite off of the main Orbi unit but can run all 3 from a switch. That makes it a lot easier for me in terms of cables.
Thanks- FURRYe38Nov 25, 2018Guru - Experienced User
You'll have to see if it works like that. Connecting the satellite to the R7000 may imped communication with the Orbi base. Then again, it may work. If the R7000 was configured for AP mode then I would say yes of course, use it as a switch. I would recommend connecting it using the recommended configuration posted by NG to minimize problems and maximize performaces. It's what I use. I have 3 switches in between my base router and satellite. Works well.
Good Luck.
