Aronius
Mar 23, 2019Tutor
Orbi with Sky Q
Hi, I installed my Orbi’s the other day , all devices are getting a strong stable wireless connection except the Sky Q’s. Connecting them to the orbi network (my virgin hub is in modem mode) is ok...
Chuck_M
Mar 24, 2019Mentor
To fully help, we need to start at the beginning.
What firmware is loaded in your Orbi's?
What is the mode your Orbis are operating on? AP or Router?
What is the specific make/model of equipment your Orbi is plugged into?
Aronius
Mar 24, 2019Tutor
Hi, the Orbi’s have the newest firmware:
They are acting as a router.
And the orbi is plugged into a Virgin media hub 3.
Thanks
Aaron
Thanks
Aaron
- Chuck_MMar 24, 2019Mentor
So your Virgin 3.0 is is modem (Bridged) mode?
Are all wifi radios and DHCP turned off as well in the Virgin 3.0?
Have you updated the firmware in your Virgin Media Hub 3.0?
Read this thread and the links:
https://community.netgear.com/t5/Orbi/Orbi-RBK50-and-Virgin-Superhub-3/td-p/1678276
- AroniusMar 25, 2019TutorOkay thanks for the information.
Yes my hub 3.0 is in modem mode.
And my Hub 3.0 has the most updated firmware, what do you mean by turning off WiFi radios and DHCP? How do I do this?- Steven_BelfastMar 25, 2019Apprentice
No need to turn off DHCP on Super Hub 3, once set it modem only mode this automatically turns off as far as I can remember.
As for turning off radios he is referring to the wireless on the Super Hub 3.
To be honest I would say set Orbi up in Ap mode and hard reset the virgin Super Hub 3
Always found Orbi to work far better in Ap mode myself.
