Kuhnline421's avatar
Kuhnline421
Follower
Sep 10, 2018
Orbi with ViaSat (modem and router in one)
Does anyone have Orbi with Viasat (exede) internet? I had it working but I don't think it was set up properly. How do you set it up? The modem is also the router.
1 Reply
  • FURRYe38's avatar
    Modem Combo Units:
    Couple of options,
    1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
    2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
