AKLGUY
Jan 09, 2019Apprentice
Orbi with wifi 6
Has anyone seen the tech specs on the newly announced Orbi?
I hope the AC speeds to the units will be faster than the 867MB (as well as the faster backhaul)
- AKLGUYApprentice
Thanks. I see it has the AX backhaul which is fine. But what about the actual PCs to the Unit speeds
Secondly if you are using ethernet backhaul. They should open up the dedicated band for the backhaul for devices to connect :p
Depends on client device or adapters used in the PC. Currenly nothing on the market yet for AX in regards to client HW.
- davidloeppAspirantIs it a waste of money buying this unit when NETGEAR plans on releasing a Wi-Fi 6 version of Orbi this summer. Yes I know a lot of devices are Wi-Fi 6 compatible but I want to know will I benefit more from OFDMA in these units.
Currently there but only a few that are WiFi 6 compatible I think. Samsung being the first with support. Not many others. I heard Apples iphone 10x is going to support it.
- PlacesandspacesApprenticeSo given how WiFi 6 is supposed to work in theory...shouldn’t the AX version of the Orbi to be released later this year support more satellites than the AC version?
- JeremyinsfApprentice
They do intend to release later this year - but what do you mean about supporting more satellites? The AC version can already handle quite a few depending on topology. The AX version will allow more streams (by AX nature) but I'm not clear how you relate that to satellite count?
- PlacesandspacesApprenticeFrom what I understand the AC version handles up to 3 or 4 satellites. If Wifi6 is more efficient etc wouldn’t the AX version be able to support even more satellites without eating up a lot of bandwidth? I am looking at running 7 satellites (for the backhaul wired connection) and 1 main unit.
