russian
Feb 08, 2017Aspirant
Orbi WITHOUT modem
Hello! How can I install Orby Wifi System without modem? I only have ethernet cable that connects to the router. I haven't got modem.
russian
Feb 09, 2017Aspirant
My ethernet has login and password(from provider)
It won't be a problem?
st_shaw
Feb 09, 2017Master
russian wrote:My ethernet has login and password(from provider)
Orbi supports Internet connections that require login and password.
Orbi is not a modem. If your Internet connection requires a modem (such as cable or DSL) then Orbi will not work without a separate modem.
Why do you think you might need a modem?
