russian
Feb 08, 2017Aspirant
Orbi WITHOUT modem
Hello! How can I install Orby Wifi System without modem? I only have ethernet cable that connects to the router. I haven't got modem.
russian
Feb 09, 2017Aspirant
My ethernet has login and password(from provider)
It won't be a problem?
djc6
Feb 09, 2017Luminary
russian wrote:My ethernet has login and password(from provider)
Page 24 of the manual describes this:
http://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
If your ISP requires a login/password, you select the encapsulation method - PPPoE, PPTP, or L2TP. Does your ISP use one of these? Can customers of your ISP use other consumer routers? If so, thats a good indication Orbi will work.
