Efrugier
May 18, 2018Tutor
Orbi won t connect to the internet
I had the orbi for a year worked fine.
This morning it wouldn t connect to the internet. White flashing light then purple.
Checked my internet connection from modem and it it fine.
any idea what is wrong ?
Do you have access to the Orbis web page?
What FW version is currently loaded?
Was a FW update done recently?
What is the Mfr and model# of the ISP modem? Built in router here by chance?
- EfrugierTutor
I could login to page. FW is the latest on both router and satellite. Don t know when it updated as I have auto update.
my model is a Tp link. I had it for 2 years. No issues with orbi before.
Could there be an issue with FW update ?
What is the model# of the ISP modem?
Try a power OFF of both Orbi router and satellite for 1 minute then power back on. If this does nothing, try a factory reset on both router and satellite and set up from scratch...
