lowepg
Dec 28, 2017Apprentice
Orbi won't save my wifi password?
For some reason, orbi keeps changing my wifi password- and its one ive been using forever! for example: my password is "password%%" orbi keeps changing it to "password12345" ive tried reboo...
lowepg
Dec 29, 2017Apprentice
thanks- I see that now after searching a bit.
It appears they've known about it for a while and still no fix?
Changing passwords is really unacceptable - especially given the premium price Netgear demands for this product. I have a dozen+ devices that need to connect to wifi throughut the house (smart home devices, ring products, tv boxes, etc, etc, etc). Changing all the passwords becuase Netgear can't get this fixed is infurating.
supercubdude
Jan 02, 2018Aspirant
Can we revert to the firmware before V2.1.1.16 where it seemed to work fine?
sj
- DarrenMJan 04, 2018Sr. NETGEAR Moderator
Yes you can go back to the 2.0 if needed but you have a beat 2.1.2 that has fixes for the 2.1.1 firmware you can find that here.
https://community.netgear.com/t5/Orbi/OrbiOS-2-1-1/m-p/1476960#M19962
DarrenM
- lowepgJan 04, 2018Apprentice
Reading the notice for that beta firmware, it sounds like it only addresses the cpu issue and reboot issue NOT the passowrd bug.
that's still "coming soon" :-(
