hunterpav's avatar
hunterpav
Follower
Jan 09, 2018
Orbi WPA3 protocol
Looking to purchase an Orbi system in 2018. When will the Orbi use the new WPA3 wifi protocol ?
  • Probably not for a long time.  WPA3 is not expected to be released to manufacturers until "late 2018".  After release it will probably take a while to so it in products.  Past experiences with high-end enterprise stuff usually sees new standards appear in products 9-12 months after release to manufacturer.
  • FURRYe38's avatar
     Requires support from chipset vendor. There's more than to just adding it to a router or device. It's supposedly been ratified, however doesn't mean it's being implemented now. Going to take some testing time and development on many levels to get it working for all current and new generation devices. Stars with encryption and chip set and FW mfrs. I would not expect anything this year. Maybe next.
  • FURRYe38's avatar
    You'll need to contact the wifi certification org and the chipset mfrs to see if there is any more info on WPA3 progress. They are at the root and will have more info than the end product Mfrs will. I was told that it starts with the chipset Mfrs and there support. Broadcom, Intel, Ra-Link, etc. hold the chips.
    • DavidUnboxed's avatar
      DavidUnboxed
      Star
      To be clear, the links I posted are from the wifi certification org and the linked PDF shows the certification of Qualcomm's (a chipset manufacture) erference design based upon the IPQ8065 and Wi-Fi componet QCA9984/5.  As I recall, from a 2016 press release, Netgear selected Qualcomm to colaborate with on the Orbi.  A quick google seems to confirm Orbi RBR50 & RBS50 uses Qualcomm's IPQ4019, the same as Velope.  Hopefully Netgear is ahead of the game and can quickly determine if Orbi will support WPA3.  Suave buyers will consider a support plan for the same in choosing their solutions.
  • FURRYe38's avatar
    Im sure NG will be updating to WPA3. Just ALL the rest of the router and device Mfrs. Just when is the big question. All comes down to chipset vendors, implementation, developement and testing. Maybe a while though. Realistically, it's not happening over night. :smileywink:
      DavidUnboxed
      Star
      I did not realize you expected it to happen overnight.  I don't know where you got that idea.  I certainly never said such or would expect it.  Based upon my experience having worked for 3 fortune 100 companies that make devices with firmware - that idea is insanity.
      What is not insanity is expressing my hopes that Netgear is ahead in the game with an initial release near the front of the line, an option to alow customers willing to push the bleeding edge to be a guinipig test group, and communicates quickly about prospect of the device supporting the new standards.  Some of us have a much higher tolerence for such than others.
      This is certainly not unreasonable and certainly not pie in the sky thinking.
      Nevertheless, if a family member or friend asks which router they should buy today while I am a great fan of Orbi - I cannot recommend it.  If their router is down they will be advised to acquire one of my old routers from the pile in my garage and/or a cheap alternative if it can meet the needs while they await support statements from the vendors.
      David T.
