robstoneley
Sep 28, 2018Initiate
Orbi WPS and Canon MG7570
My Canon MG7570 printer is unable to pick-up any signal from my Orbi router. I have pressed the Sync button on the Orbi and then had my printer attempt to connect but it has failed each time I have ...
- Sep 29, 2018
thanks - after fumbling around and trying this solution I found elsewhere (set the 2,4 Ghz to Channel 10), I have got it working
Sep 28, 2018Guru - Experienced User
What FW is currently loaded?
MAKE SURE your printer FW is up to date. Some printers wifi isn't the greatest. Does the printer have a LAN port or just USB port?
What security modes are you using on the Orbi? Try Disabling WPA temporarily on the Orbi. Then try to see if the printer will connect? If so, then try WPA and TPIK and test. Then try WPA2 and AES only and test.
MIMO, Daisy Chain, Fast Roaming, IPv6. Save settings and reboot the router and satellite(s).
- robstoneleySep 29, 2018Initiate
- FURRYe38Sep 29, 2018Guru - Experienced User
Interesting. Seems to be a printer issue. Normal channels are 1, 6 or 11.
Enjoy. :smileywink:
- pdmartinOct 09, 2018Aspirant
Just to confirm. I also had problems connecting my canon ip7250 to orbi using wps. Failed at least 3 times. Changed the 2.4Ghz chanel to 10 and it worked first time.
