Kirlieq
Aug 27, 2019Aspirant
ORBI45 authentication problem
My kids are trying to join each other in the new Terraria update from their mobile devices and are being asked authentication questions that I assume I have to answer as the account holder (High Scho...
Aug 28, 2019Guru - Experienced User
Is it the Terraria site asking for this or the netgear gui asking these questions?
From you putting ORBI45 in the title, it makes it look like you left the ssid with the factory ssid. If you didn't setup security quesions, it'll still ask for them and you are unable to put in correct responses because they weren't setup correctly. Just trying to figure out exactly what is going on.
Are you able to log into the orbi gui? routerlogin.net? or is this where the issue lies?
Kirlieq
Aug 28, 2019Aspirant
It's either Microsoft Edge or netgear asking, but I'm fairly certain its not Terraria. Reason is as I'm trying to get wifi back and login to orbi, I'm getting Microsoft Edge login window, can't get in on that and after a few attempts, I get the authentication questions again. It was my son who originally got the questions and I don't know how he got there.
- Retired_MemberAug 28, 2019
Kirlieq wrote:It's either Microsoft Edge or netgear asking, but I'm fairly certain its not Terraria. Reason is as I'm trying to get wifi back and login to orbi, I'm getting Microsoft Edge login window, can't get in on that and after a few attempts, I get the authentication questions again. It was my son who originally got the questions and I don't know how he got there.
WOW....you may want to start form the beginning.
The only thing I can offer is that there was another user here that had a similar problem with security questions. He/she was using Chrome browser.
https://community.netgear.com/t5/Orbi/RBR50-password-recovery-failure/m-p/1788627#M68375
Your OP stated the kids were trying.......were they using Chrome?
- plemansAug 28, 2019Guru - Experienced User
Agree with Retired_Member on starting back from the beginning. I'd redo the reset 1 more time. On rare occassions, I've needed that 2nd reset to get things running smoothly. Plus once you get it setup, make sure your firmware is the latest.
