low's avatar
low
Orbi89 v new wifi Comcast Modem
Two questions:
1)  Signing in with password ("password") doesn't work nor does any other password I have.
2)  Comcast sent me a new wifi MODEM. Does this new wifi MODEM with Voice (VOIP) work with my new ORBI89 or does it interfere. In other words, does it extend the capabilities of ORBI89?
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Low
    If password is not working you may have to do a factory reset to the router and do the setup agian. to do this you hold the reset button down for 10 seconds. As for the comcast modem if it has a option to make it modem only or able to be bridged you will want to do that before connecting it to orbi.
    DarrenM
  • Do you know the model number of the new Comcast device. Some support bridged others don't.  I have a friend that recieved a new Xfinity modem for X1 and has no option for briding the IP address or even turning off the Wifi from the UI.
    • low's avatar
      low
      I spent several hours with Xfinity (Comcast) involving their new Modem/Router. Before installing it, I called Comcast Tech who advised me there would be NO issues of compatibility. HOW WRONG THEY WERE!  I lost connectivity to the Internet and my VOIP (i.e., telephone service).
      I was forced to disconnect the Comcast M/R. I then recalled Comcast tech services again (800)934-6489) and spoke with a very professional, knowledgeable and charming techie (Phil).  While it took some time, he walked me through REINSTALLATION of the new M/R, got me connected to the Internet and finally got my phones working.
      He said he had to UNBRIDGE the Xfinity M/R so my ORBI Router could work --- from his end on Comcast equipment. After the Comcast connections were reestablished he recommended I connect my Ethernet directly from the ORBI Router to my iMac and NOT use the Ethernet connections from the M/R  ethernet slots.
      It worked perfectly...after hours of frustrating effort.
      On a side note: A Comcast rep called me this morning stating she noticed many calls and Reference Tickets regarding my problem and wanted to know if everything was worked out. I thought that was very responsible of Comcast.
  • It does not extend your Orbi signal. I had to have Comcast disable the wifi radios on their modem. I was told that they would interfere with the Orbi signals
  • Now if only I could get my ethernet ports working on the satellite.... Still a work in progress
