mteigers
Feb 25, 2017Aspirant
orbilogin.com doesn't work in AP mode
I'm running into an odd situation after switching to AP Mode where I can no longer access orbilogin.com. What's strange is I cannot find my router at all. I did a quick network scan of every device running on port 80 and the router is not there, I can access my satellite just fine but cannot see the router.
My wifi works great with no issues, I just can't see the router to modify settings.
Any ideas?
Edit: so more oddities, the orbi router has a solid magenta ring, which from the docs 1. should only happen to the satellite and 2. means the satellite cannot talk to the router. I can most definitely reach the satellite and it says it's fine.
- st_shawMaster
orbilogin.com definitely works for me in AP mode.
In AP mode the router will turn magenta if it becomes disconnected from the device acting as the router.
To use the router in AP mode, you need to connect the Yellow "Internet" port on the Orbi router to a LAN port on your existing router. Check the cabling. If that doesn't work, power-cycle the orbi router and satellite.
- SDJTutor
I have the same issues except that I'm unable to connect to the internet. The solid magenta ring, no access to orbilogin...
If I hard reset the Orbi unit and try to access orbilogin.com I can only get to the setup wizard which is useless as it keeps telling me I don't have an internet connection. Which I know....I'm trying to change it to an AP...
Soooooo frustrating...
- Dan_HApprenticeTry using the phone app, it's a terrible app but it will help in that situation.
- SDJTutor
Thanks Dan. The phone app might work if I could get the phone to connect to the Orbi wifi network! But even that isn't working at the moment...
- mteigersAspirant
Yeah, I'm seeing the same result. The mobile app doesn't work. I'm still in a bad place sadly. I've lost the setup wifi password and cannot connect to the Orbi's at all to see anything. I'm worried if I reset them I won't be able to log in. I know `tuba` was in my password, but don't remember beyond that.
