Drewmama
May 16, 2022Guide
Orbilogin.com help
I was changing my settings in orbilogin.com to enable daisy chain. When it was about to finish rebooting, it went to a screen that said "Connect to the Orbi Wifi Network" and now I cannot get back into the admin settings. I can see the router and 2 satellites in the app but the order of the chain is wrong. How can I fix this? Or just go back and disable daisy chain?
What Orbi model do you have?
How was the RBS placed? Star formation is most common. Daisy chain is RBS placed out in a line from the RBR.
Try turning OFF the RBS and turn them back on in a different order.
- DrewmamaGuideI have a RBK22/RBR20.
I did what you said and it looks like it worked. The reason I wanted to try daisy chain is because my house is a long rectangle. I'm trying a new modem and it's upstairs at one end. I get no coverage at the other end. I put one satellite downstairs at one opposite corner and another satellite downstairs at the other end.- FURRYe38Guru - Experienced User
This series is one of the few that you can disable the Daisy Chain feature found under Advanced Tab/Advanced Settings/Wireless Settings.
