AmitR
Apr 23, 2018NETGEAR Employee Retired
OrbiOS 2.1.4 availability
A quick update. We're about to release an updated version of OrbiOS 2.1.4 in the next few days through our auto-update mechanism for all Orbi models. When it goes live, you should see a prompt in t...
pm73it
Apr 24, 2018Aspirant
Hi, the web interface tells me that the updrade is available only for satellites and not for router...
How is this?
any direct link to update manually?
wifi_en
Apr 24, 2018Star
Rlease notes says still there is know issue with 2 or more satellite
Bug Fixes:
- Fixes the issue where Orbi app displays a “Router Not Setup” message and requests the user to setup their Orbi router again even though the user already completed the Orbi router installation.
Known Issue:
- When user has two or more Orbi satellites connected to Orbi router using Ethernet backhaul connection, an Orbi satellite might not connect to the Orbi router after the firmware update. A workaround solution is to reboot the Orbi router and then wait for 2 –5 minutes.
So should we still wait for a fix?
