AmitR
Apr 23, 2018NETGEAR Employee Retired
OrbiOS 2.1.4 availability
A quick update. We're about to release an updated version of OrbiOS 2.1.4 in the next few days through our auto-update mechanism for all Orbi models. When it goes live, you should see a prompt in t...
pm73it
Apr 24, 2018Aspirant
I'll try to disable sonos... but my guess is thet when if plug it again it will be the same...
my switch is unmanaged, so it shoub be not a problem.
As of today in that switch there is sonos and sky q plugged, and both work fine
cscheiene
Apr 24, 2018Star
Wiring more than one Sonos unit killed my Orbi. I don't think this is only a Orbi problem, it requires spanning tree protocol or something on the router. Only wire one Sonos unit fixed it for me
- sbeares1210Apr 27, 2018Guide
For Sonos only hardwire one of them. Let it use the sonos network for the sonos, works much better. When you hard wire all sonos features it limits functionality as well. Found all this out figuring wiring all of them was best, but then I tried to setup surround sound for tv and after lots of sonos forums found out best to use sonos network.
- AcerunApr 27, 2018StarApparently this is not very popular but I have never experienced these kind of speeds that I am experiencing now… This latest update has radically optimized my system… I’m sorry everyone has trouble but my system is the best it has ever been… By far
