AmitR
Apr 23, 2018NETGEAR Employee Retired
OrbiOS 2.1.4 availability
A quick update. We're about to release an updated version of OrbiOS 2.1.4 in the next few days through our auto-update mechanism for all Orbi models. When it goes live, you should see a prompt in t...
Eric90i
Apr 24, 2018Star
Is 2.1.4 stable? I’m still on 2.1.2.18. Has anyone successfully updated through the app with rbk50 system and then not heard anyone yelling about the WiFi not working?
Sdiver2489
Apr 24, 2018Apprentice
Yeah I literally just rolled back to 2.1.2.18 because I got tired of random issues like my RainMachine losing connection after a few days. I think I might stay on this for a while. I am curious if 2.1.4 is considered a beta still? I haven’t gotten a notification for an update even if I manually check and I’m wondering if it’s because I’m not on a beta at the moment.
- Eric90iApr 24, 2018StarSo my app shows the option to update to 2.1.4.10 currently. Usually they don’t give you the phone app update feature if the firmware is still beta, but who knows. Did you roll back from the 2.1.4.10, if so why?
- Sdiver2489Apr 24, 2018ApprenticeNo sorry I rolled back from 2.1.3.4. I am worried that the issues I experienced won’t be fixed because the “bug fixes” of this release are pretty darn small. I’ll wait to hear reports on this one...I hope it fixes more than the release notes lead on.
- drsg64Apr 26, 2018Guide
This morning the system updated and never came back online! App can't conect with system even after full reboot.
- FURRYe38Apr 26, 2018Guru - Experienced User
Do you have access to the routers web page via wired PC or wireless PC/laptop?
Whats the Mfr and model of the ISP modem the routers connected too?
Do you have Satellilte(s) connected? Wireless or wired backhaul?
Try powering down both Obri router, sattelllite and ISP modem for 1 minute. Power up the ISP modem first and let it sync. Then power ON the router. If you get a BLUE LED or it goes from White to OFF, check router web page access then internet access with a PC/laptop. If it's working here, turn ON the Satellite and let it sync and check it's Top LED Color. Hopefully White, Blue then OFF.
- YanicMay 01, 2018InitiateWe installed latest firmware last week, non stop daily crashing. I want to return this crap paperweight of a router. Fed up of Orbi support. Or lack there of. Stop bricking routers and be transparent
- FURRYe38Apr 24, 2018Guru - Experienced User
If you update to v2.1.4.10 from v2.1.2, you'll need to do a factory reset and set up from scratch. There are major changes which include items in v2.1.3.4 and now v2.1.4.10 which need a good clean slate to start after installed. Others have posted that problems continued after updating to v2.1.3.4, the problems went away after doing a full factory reset and set up from scratch. I've seen this as well.
