AmitR
Apr 24, 2018NETGEAR Employee Retired
OrbiOS 2.1.4 availability
A quick update. We're about to release an updated version of OrbiOS 2.1.4 in the next few days through our auto-update mechanism for all Orbi models. When it goes live, you should see a prompt in t...
Sdiver2489
Apr 25, 2018Apprentice
Yeah I literally just rolled back to 2.1.2.18 because I got tired of random issues like my RainMachine losing connection after a few days. I think I might stay on this for a while. I am curious if 2.1.4 is considered a beta still? I haven’t gotten a notification for an update even if I manually check and I’m wondering if it’s because I’m not on a beta at the moment.
Eric90i
Apr 25, 2018Star
So my app shows the option to update to 2.1.4.10 currently. Usually they don’t give you the phone app update feature if the firmware is still beta, but who knows. Did you roll back from the 2.1.4.10, if so why?
- Sdiver2489Apr 25, 2018ApprenticeNo sorry I rolled back from 2.1.3.4. I am worried that the issues I experienced won’t be fixed because the “bug fixes” of this release are pretty darn small. I’ll wait to hear reports on this one...I hope it fixes more than the release notes lead on.
- drsg64Apr 26, 2018Guide
This morning the system updated and never came back online! App can't conect with system even after full reboot.
- FURRYe38Apr 26, 2018Guru - Experienced User
Do you have access to the routers web page via wired PC or wireless PC/laptop?
Whats the Mfr and model of the ISP modem the routers connected too?
Do you have Satellilte(s) connected? Wireless or wired backhaul?
Try powering down both Obri router, sattelllite and ISP modem for 1 minute. Power up the ISP modem first and let it sync. Then power ON the router. If you get a BLUE LED or it goes from White to OFF, check router web page access then internet access with a PC/laptop. If it's working here, turn ON the Satellite and let it sync and check it's Top LED Color. Hopefully White, Blue then OFF.
All my gear is Netgear, the router is a CM1000 and im runing a one gig network. Right now everything is unpluged till i can figure out whats wrong.
- YanicMay 02, 2018InitiateWe installed latest firmware last week, non stop daily crashing. I want to return this crap paperweight of a router. Fed up of Orbi support. Or lack there of. Stop bricking routers and be transparent
